I cleaned out my throttle body for the first time ever and all it cost was a $2.50 can of cleaner. I cleaned it because of a rough idle. It helped and all of the sudden my car is very peppy. Maybe it is just thanking me for giving it a little TLC.
oops :****: ...I hadn't seen him post here for a couple of months...hopefully he'll see your question.Acurately Legendery said:Well actually I was aiming that question towards Biyonic.![]()
I use a generic carb cleaner, its a black and red can @ canadian tireblacklegendcoupe89 said:What throttle body product did you people use?
One thing that confuses me a bit: many of the TB cleaning products recomend spraying into the TB with the engine running, is this because it is supposed to not only clean the TB but the interior of the intake main manifold? To me it sounds like it wouldn't be that healthy for the engine to combust lots of TB cleaner (I guess that is why they also recomend driving the car right away after using the product). I also read in other places that to get the best results the TB has to be removed and cleaned by hand just as you did. I plan to do that, so my question is: once I remove the TB and clean it, would it be still good/bad to spray TB cleaner with the engine running?body9599 said:no...i removed the TB and cleaned it with the spray and a toothbrush...that's the best way to get it really clean.
