First of all you need to reconnect the 3 wires that you cut. Next get a voltmeter and find out where your issues may be coming from. The switch may not be getting any juice or the connection to release the window is loose or may not be connected or even a blown fuse could cause the issue. find out where the bad connection is and make the connection in order to restore your child lock switch to normal operation...
