ChrisK, corner clearing ?'s
819 Views 2 Replies 3 Participants Last post by  DaTimez420
Wassup man. Ok, I remember you saying you cleared out your corners on one of your coupes before. I have JDM Corners but want to get some OEM ones(I sold mine) and try clearing them out like you did...
Did you do it just like these instructions say to? http://www.legend.org/performance/aerodynamics/aerodynamics-4.html
Do you know if it will work for the G2 Sedan? Does it also have the screw that releases the diffuser?
Any drawbacks I should know about? Thanks man.
Sorry, you can't do it on a G2 Sedan. On the G2 Coupes, the inner lens has the orange lens, and that whole thing is covered by a clear outer lens. On the G2 Sedan, the amber section is part of the outer lens, so you would have a big hole in your corners if you where to remove the amber section.
ouch...thanks for the info before i went out and tried that which i had been recently considering! :)
