im not sure if i can intall a cold air intake cause down where the air box is behind the front wheel well, the plastic lining got torn/worn from rubbing against my tire at one time...so theres barely a cover there...and im afraid water will get in the intake if i install one there...any suggestions?.....
the only way water can travel up to the throttle body with a CAI is if u'r filter is completely submerged underwater. even with that, you can install a bypass valve and you should be fine. i've had my CAI for a year now and i've been completely under water and no problems.
-j
