That is a great find! All that for $1,200! I wonder if they are in Augusta, GA.Steveman09 said:
Later!
Lee
That is a great find! All that for $1,200! I wonder if they are in Augusta, GA.Steveman09 said:Check out what I found on ebay :
http://cgi.ebay.com/ebaymotors/JDM-...ewItemQQcategoryZ33615QQitemZ8009766326QQrdZ1
EVERYTHING INCLUDED FOR A C20T Conversion!
Yes there are!sleeprlegendcp said:That is a great find! All that for $1,200! I wonder if they are in Augusta, GA.
Later!
Lee
This is sucky timing. I just started my search for another engine. I finally gave up on a good C20. If I go OEM turbo I want the C27TT. I am also not sure what kind of upgrades you can do with that winged turbo. Velocity will only do any major work on my G1. That is just because they know me, and I send them a good bit of business. I know a few people I can bring this up too. I am just really set on my new plans.swift said:someone would make the cover of hondatuning easy with that done...
someone better frigin do it.
Hey lee, would Velocity be interested??? cover shoot...advertisement. :bowdown:
Honestly, no one knows! If the C20 can be put on the 2.7 you will open a whole new market for the Legends and Accords. My plan still goes way beyoned that.Badjack10 said:ok guys i am seriously considering this!
just a few questions.
do you guys think that the turbo could be swaped onto a 2.7. what i mean is everything that is needed such as the intake mani ect....
what all do you guys think is interchangable?
anyone??acuralegend_racer said:hey everybody... does anyone know if its possible for a C27a1 manual tranny will fit with the C20tt?? I mean it only comes with automatic right?? any info greatly appreciated. I mean under $2000 wow! I was thinkin about it.
I have already done research on this subject and everything will bolt to the C27A1 block. But you will have to find ways areound the EGR sensing system on the C27A1 ECU, install a check valve on the MAP sensor, install a turbo timer/boost controller and a S-AFC II to adjust fuel mixture during different throttle %'s and RPMs. Its a buch of work but it can be done.88_acro said:its the same block but no one can be sure because no one knows we can only ASSUME
I was talking bout the c20TT... 2.0 litre twin turbo for the G1. I saw that they only came with automatic so I was wondering if anyone knew of it.. My original question was will it bolt onto a manual tranny??1_Hot_Legend_L said:I have already done research on this subject and everything will bolt to the C27A1 block. But you will have to find ways areound the EGR sensing system on the C27A1 ECU, install a check valve on the MAP sensor, install a turbo timer/boost controller and a S-AFC II to adjust fuel mixture during different throttle %'s and RPMs. Its a buch of work but it can be done.
Later!
Lenny
Oh yeah, it has the same bellhousing bolt pattern as the c25 or c27. You'll just have to use the clutch assy. and flywheel from the old engine!acuralegend_racer said:I was talking bout the c20TT... 2.0 litre twin turbo for the G1. I saw that they only came with automatic so I was wondering if anyone knew of it.. My original question was will it bolt onto a manual tranny??
