to flush all the coolant out of your car what must you do? i looked in the DIY section....only flushings is for transmissions. i know about the drain thing under the car....but i want ZERO coolant in it so i can try bar's leaks head gasket repair. i searched for that too....and found mixed reviews so i might as well try it. i just wanna be sure i flush everything correctly.
ill go through what i THINK is the proper procedure then you all can correct me....ok. open drain plug, let crap come out. close drain plug. fill radiator with water, run car til warm, let cool down, open drain, close drain, refill with water (repeat like 3 times?) or until all clear water comes out of drain. is this a proper coolant flush?
then, just so yall know, you add the stuff, fill rest with water, run til warm, top off with water, run at higher rpm 1500, let sit, top off with water, let sit for 1 hour. drain. leave plug open and cap off for 12 hours. flush like above, and then refill with proper coolant. tada! no more bhg!! :bowdown: :2cool:
