I have a suspicion that my cooling fans may not be working. In order to be sure, I was wondering when are the fans supposed to come on. Its been really cold here and I haven't driven much in the past few months to heat up the car enough to make the fans come on. I recently replaced the rad and did the bleeding procedure and I noticed that the fans didn't come on once the car had reached normal operating temperature. I have a new engine, new rad and just changed back to a new OEM thermostat. I know both fans work because when I turn the ignition, I can hear them running and then they turn off once the car is started.
If the fans are not working I am guessing that either the rad fan sensor (at the bottom of the radiator) has a loose connection or I didnt connect the FCU properly when I swapped the ECU. Can someone tell me what exactly tells the fans to come on once there is a need for them to come on?
Also, on a cold start, the initial RPMs are 2000 and then gradually come down to ~1000 (takes about a couple of minutes in sub-zero temperatures). However, sometimes if I shift into drive while the RPMs are at 1500 and then put it back into park, the RPMs start to fluctuate between 1500 & 2000 (couple of times) before settling at ~1000. I know for a fact there is no air in my system. I just compression tested the engine; its fine. Are these signs of a dying Coolant Temp Sensor?
I need to figure this out before it starts getting warm here.
