I have to admit I've owned a Legend (well, technically, two at this point) for FAR too long without understanding how the cooling system works as completely as I should.
Last weekend I bled the cooling system per Mike Diaz's instructions because I could hear trickling through the motor when I drove the car around. I've been watching the system carefully since and I'm a bit baffled by it's behavior at this point.
So... the questions:
For starters, when bleeding the system, I was losing coolant primarily from the open radiator cap. Is this unusual? Having never done it before, I was really expecting to get fluid out the bleeder screw instead.
Secondly, why is bleeding done with the cap off? It seems to me it'd make more sense to leave the cap on and fill the reservoir, forcing the car to leverage its own facilities to keep the fluid level regulated and then you'd just have to keep the reservoir full.
Anyway, all this comes from the fact that I believe I'm losing fluid. I'm not seeing anything in the tail pipe, I'm not seeing any evidence of leaking so I can only theorize that either the system is still trying to stabilize air out of itself or the coolant is disappearing into the cumbustion chamber and I've got some serious work cut out for me on this engine in the not terribly distant future. Of course, it should be noted that the car has NOT been overheated... but I guess that's not necessarily a reliable factor in dismissing head gasket failure given that the trickling noise I was hearing indicates air in the cooling system.
Help's appreciated. I'm sure I could search my way through this question but sorting through the overheating and cooling system threads around here is pretty helacious :hide:
Sorry for the novel!
