1 - 6 of 6 Posts
I was wondering if the Legend Sedan and Coupe had the same suspension components. In other words, would the whole strut/spring assembly from a sedan fit directly on a coupe? Thanks
Old S*hool Member
Yup - they will fit no problem.
The Shock Absorber (Damper) carries different P/N depending upon Cpe vs Sedan and Sed w/or w/o GS. Suspect the valving to be different.
Old S*hool Member
Yes, thats because the coupes shocks gave a slightly stiffer ride from what I've heard on this forum (or the old legend.org forum).
Yeah, just different stiffness settings from the factory. If you are going to buy new shocks though just get some Koni's and if you can't afford those then get the Tokico's they are both better than Stock, but I think that the tokico's probably give a really stiff ride since they aren't adjustable. I have koni's and adore them.
1 - 6 of 6 Posts
