1 - 2 of 2 Posts
when removing the front bumper on a 94-95 sedan, i know how to do it, but does anyone know the specific tools needed for this job? and also, my shiftgate bulb that lights up the gears when the headlights are on have burnt out (i'm assuming because it doesn't illuminate anymore), anyone know how to replace this? thanks!
0000$$$$0000####0000
If it uses the same bolts as the Coupe, which it probabaly does, you need a phillips screwdriver, a 10mm socket, and a 12mm socket. You probabaly will also need an socket extention bar to reach the 12mm bolts that hold the bumper in place.
1 - 2 of 2 Posts
