Does anyone know for a fact if the crank pully can be put on any way besides TDC? Is there any kind of notch or anything to prevent this from happening?
The reason i ask is that i just put a new #1 piston in my car and while and after i put the rod bearing on i put the piston at TDC, I took a long wrench attatchment and push it against the underside of the piston and turn the crank pully untill the attatchment neither goes up or down. I do this so i dont have to keep getting up and looking at the TDC mark while im under the car.
Well i got up and looked and the notch on the pully was past the aiming mark by like 2 1/2 inches.. so i go back under the car and the piston is at TDC
Is there somthing funny about these legends i should know? doesnt the first piston have to be at TDC (far as it can go up) and the cams on their marks too to set it at TDC?
its got me worried, i dont know how many degrees the pully notch is off but its about 2 1/2 inches
so im wondering if some one changed the timing belt in the past and pulled the pully off and put it back on off a few degrees. so does any one know if thats possible? I know the cam pulleys only go on the cam one way but not sure about the crank pulley..
