Well, I figured while I am taking my engine apart I might as well do the timing belt, it's been ~83k since it was last done.
So here I am trying to get that darn bolt off. I read through old topics on it, tried the impact, tried jamming the cam gears (belt slipped) and finally I came up with a solution. A steering wheel puller, 1/2 3" extension bar and a 5/8" wrench did the trick. I first tried a "Forged" Made in Taiwan 11/16" wrench, this is what happened:
Then the 5/8" I used was a Craftsman. Worked fine
The contraption I came up with was sort of a makeshift version of the Honda tool. Here's a pictures of it:
and this one too:
Turns out the bolt was so tight because the last person to do the timing belt put permament loctite on the threads of the bolt. It was flaking off. Took a total of ~3 hours to remove one bolt.
and this one too:
