tons of white smoke, rough idle, white cream in oil.. no oil in the radiator (atleast not yet), almost perfect compression... what gives?
I just replaced cylinder 1's piston and a headgasket, fired it up and its running like crap, it stalls every few minutes or so and its got a ton of white smoke that doesnt smell like syup at all and seems to dissapear after floating for a minute, but does kinda smell like actual coolant i guess? the oil cap and valve covers have a alot of white cream inside like coolant is mixing but so far i havent seen any oil in the radiator. pulled all the plugs and smoke came rolling out cylinder 1 and 2. Cylinder 1's spark plug is covered in burnt oil and cylinder 2's was a little wet. the plugs only have like 30 minutes run time on them.
I guess its the headgasket but every cylinder is holding 179-180psi, thats almost perfect! there is also no oil showing up in my radiator either so thats strange..
anyone think the coolant could be entering the intake manifold somehow and blowing past the rings into the oil after it gets into the cylinder? that would explain why no oil is in the coolant..
Maybe the rings could have blown in cylinder 1 and that explains the oil on the plug and maybe gas could be making the oil frothy? it sure doesnt smell like gas and doesnt explain #2 smoking..
