start small and simple troubleshooting >>>>>>> c/c >>>>>>(cruise control)
1. check the connections on c/c actuator, c/c main switch and steering cable reel and button
2. check fuses {No. 13 and No. 20}, check horn relay, check ground connection.
3. check c/c cable and throttle body,
4. check speed sensor, if speed sensor is faulty and [D4] is flashing then c/c will not activate.
5. check c/c unit located passenger side of kick panel
* if SRS is lit and airbags have been previously deployed. the cable reel/slip ring may need to be changed because it shorts out on impact and deploys airbags
6. check for poor/broken/corroded wiring. ensure optimal connection.
