cruise control=kill switch?
3.9K views 11 replies 8 participants last post by  Daniel_S
I was planing to install a kill switch, not one that connects to the ignition starter, but rather connects to the fuel cut off line. I was hoping to wire the cruise control button, so whenever it lights us green (on), i would be able to start the car. Or even better, how about having the fuel cut off wire up to the highlight switch, so whenever i wish to start the car, the head light must be one. I am tired of the obvious hidden clicker/switch that can be found, can anyone assist?
#2 ·
sounds like a cool idea. unfortunately, *most of the time* the thiefs just hard wire the fuel pump right at the pump because its easy to access quickly and bypasses any "hidden switches" or "cutoffs" in the car. You might slow them down though!
#8 ·
see what Im getting at your car pc project with the help of the transporter series has made me think of doin somethin alittle crazy later this year, but I think there is a possible emergency switch that can be applied for emergency situations..? right?
#9 ·
Yeah, I'm sure you can put in a primary that will override the computer. All in the way they are wired together...
Primary-------computer-------pump
|________________________|
The primary would bypass the computer to activate the pump.
