1 - 20 of 25 Posts
P*mp!
ok i had this idea of removing the amber....and replacing it with a piece of clear plastic,.........IT WORKED!!!!!.........it looks a bit amateur up close.......but just looking at it you cant tell.........!!! im only 1/2 way done got the left side to do first thing tomorrow.........feeeedback!!!!
Before:
After:
P*mp!
Discussion Starter · #2 ·
pics r kinda crappy,...i'll take more in the morning.......
LEGEND
hey bud, u gotta put the pics online or they wont show up for us, go somewhere like imagestation and upload your pics there.
P*mp!
Discussion Starter · #8 ·
here r the pics
P*mp!
Discussion Starter · #9 ·
hows it loook guys? honestly???......
you can not link the pics off your hard drive, no one can see them
you have to upload them onto a web server then link them here.
P*mp!
Discussion Starter · #11 ·
oooooooooo
whoops....im working on it right now,.........
P*mp!
Discussion Starter · #14 ·
ThaAcSwerver said:
sweet......could you post instructions? i'm interested in this DIY. Where did you get the material?
why would you do this? clear corners for the sedan can be bought for less than $30 a pair now. Now if you can make euro clears, then I'll be interested.
Hmmm, those don't look much different than the aftermarket clear corners you can buy...Look identical infact...Now if they had a JDM clear(non-white plastic) look to them, that would be better.
P*mp!
Discussion Starter · #18 ·
actually.......
it would not be hard to do that,.....i could have done that,...but i decided to go with the smoked plastic because i had some lying around the house,.....this mod can easily be made to make them look like euroclears,......all you need is a dremel,........the plastic u want to use,......and a sealant,........i used silicone,....but whatever floats your boat............ just break off the amber,.......BE VERY CAREFUL..........i used the dremel to then chip off the excess,......then i cut into shape the replacement piece,......then cleaned everything up,......and sealed it in with silicone,.......thats pretty much it,.....i didnt spend 30 dollars,.......this mod was free,.....i had all the materials,.......all you need is a little time and patience,.....it took me a little over 3 hrs to do both sides,.............:-D
my point exactly........and its free. just like "why buy a CAI when you can do it Leons way and achieve the same result?"
Re: actually.......
how did you get the new peice to curve in the shape of the corner lights. You should try this with the tails.
Also can you get a clearer pic and a closer pics, I want to see how you sealed up the lense. Thanks
1 - 20 of 25 Posts
