1 - 13 of 13 Posts
I have 15" factory wheels and am considering larger wheels w/ low profile tires. I've heard that the larger the wheels, the rougher the ride. Any truth to that? Would there be a big difference in feel and handling between 17's and 18's?
1993 4-door LS
its not usually because of the rim size, its because of the tires. the lower profiles have a harder sidewall and less flex. you should notice an increase in handling, i can tell when my brother puts his 17's on his car.
HEY! 4doorLS, ur from Edmond OK? cool! i was born there, moved before i really remembered how it was. well jus wanted to say hi! i really dont know anything about tire sizes, but 18's would look better on the Legend.
If I could go back and do it all over I would do 18's because the Legend is such a big car. Now that I have lowered my Legend my 17's look a lot better, but the 18's would just be killer. I think that 19's aren't really working for practicality.
did you know....larger the diameter of your rims, the slower your car becomes :eek:
i guess so thai95. But don't blame me if you get burned by some stock car :D ....just kidding yall
See while speed racer flies down the block at 100mph i'll cruise at 15 and spot that PYT comming down the block....
Now that's PIMPIN' on diez' y Ochos...:D
It's all about what kinda rim you get too. There are a lot of 17" rims that are heavier than some 18" rims. The wheel that I use, the ADR GT-Sport is a pretty light rim so even if I was using them in 18's I think that they would only be like 19-20lbs.
But the faster your car goes the more you need larger wheels. I don't think it's so much a matter of weight but wind resistance.
1 - 13 of 13 Posts
