maybe yall may know this or not but i just found a new way (new to me) to decarbonize clylinders, tail pipe ect. I heard this from a friend and found resources all over the internet saying it was safe and more effective than chemical cleaners. the only problem is theres a rumor that a giant chunk could possibly come off and lodge in a exhaust valve while its closing and bend or break a valve but i couldnt find anyone who had actually seen it happen. im pretty sure its possible, carbon can be like rock somtimes but its probably very rare.
all you gota do is run a qt of water into the intake, through a pcv hose or other line VERY SLOW!!! i'd imagine if you put as little as a ounce at once you would cause extreme damage to the engine due to the fact water doesnt compress very well at all. just use a needle for a basket ball or somthing to suck the water up with, or use a spray bottle. its good to give her some gas to avoid hydrolocking it.
basically the water flash boils when combusted and steams off carbon on the piston heads, cylinder walls, exhaust manifolds and muffler, it wont work for anything before the combustion chamber like tb or intake manifold
i dont know what this would do to a cat since i dont have one and didnt bother looking into it. i'd imagine its not good though.
im gona try it today and see what happens, im at 180psi 13 off factory spec right now so after this i hope to get some auto rx and clean the back side of the pistons too to see if that will improve compression.
