Okay, so I just wanted to share...JUST BECUASE I CAN.
I have an extra set of front brakes from an RSX type S (300mm rotor) that I am making fit my RL. Why? Honestly, its because I need to put my stock wheels back on the good ol '96 to save money for tires for the Volks. Now, since the stock wheels wont clear my 14" STOPTECH Big Brake Kit, I have to go back to stock brakes. The only problem is that I dont have pads for the stock calipers! Yes, I am being really frugal right now. I have two sets of used OEM pads for the Type S calipers, so might as well use them up right?
Now that you got the point, all I had to do was machine the center bore of the rotor from 64mm to 70mm and the rotor and caliper will bolt right up. (Machining is free when you do it yourself) The piston size in the caliper will go from stock 57mm to 54mm (Type S caliper). The rotor size goes from stock 282mm to 300mm. The end result is a shorter pedal and a 4% shift of brake bias to the rear of the car giving it a better balance and a little bit more heat capacity of the larger rotor. (Lowering the car has reduced weight transfer to the front under braking so I am able to add more rear brake to stop in a shorter distance-based on the fact that the more brake work you do at each wheel, the shorter stopping distances you will have)
Anyway, this is still a smaller brake setup than the '99-04 RL's, but I dont care because I had the stuff laying around anyways! And yes, the RSX brakes fit in the stock 16" RL wheels
FYI:
'96-98 RL front rotor is 282x23mm rotor (same as Integra Type R)
'99-04 RL front rotor is 300x28mm rotor
'02-05 RSX Type S rotor is 300x25mm rotor
FYI:
