Hmm, conflicting evidence... I'm suspicious the ecu can tell if the tdc sensor is spot on, surely there is some slop in mounting the distributor. I wonder if the issue is sensor to reluctor distance, that's what brass feeler gauges were made for I think.
As for the bearing, Paulo says he has one but lost it, roostonu says they are odd Honda only bearing, damm, not unlikely as that's what honda puts in their standard transmissions, they went out of their way to use non-standard bearings that they could control the supply of, bloody annoying.
I'll try my acura dealer for a bearing, but hey, wait, google-ing "acura distributor bearing" got me to
http://www.cbrbearing.com/monthly_specials.htm
where I found a listing for a........
"Nachi 6001/012 2NSL 12.5x28x8mm. This is the hard to find Honda Accord distributor bearing. Latest seal design from Nachi. Brand new stock with high temp grease. $19.00 Each"
Hmmm, does the internet allow us at last to locate these weird bearings from a non honda source? Even those that honda says are not available.
Whoo boy!
So can one of you, all of you, please post with bearing numbers or dimensions.
Is there more than one type of distributor? All 1st gens the same?
surely we can whip this one!
cheers, jay
