anyone have any experience with a loose rotor? my car has a vibraton at idle and i think its missing. i can wiggle my rotor bearly, like 12:00 to 12:01, my haynes manual says if there is any play in the rotor to replace the distributor, but is there supposed to be ABSOLOUTLY no movement what-so-ever?
I was wondering if it could actually be moving and throwing off my TDC sensor. i tried unplugging the TDC sensor but there was no change in idle at all. just threw a ecu code.
also, anyone know where i can get a cheap good distributor? ebay has some that claim to be run tested... but why would you pull a distributor off a good engine? they usually sell the engines with it. and even if it does work, how can i be assured it works good? my local junk yards get a legend like once every couple months and its stripped almost instantly
