WORD TO THE WISE: If you ever plan on doing the mod yourself,
do not buy your relays from
Oreilly's Autoparts. Although they are 5-pin
SPDT relays (
Single
Pole,
Double
Throw), they are
NOT the correct ones that you need. The correct ones have pins for 30, 85, 86, 87, and 87
a. The relays from Oreily's are 30, 85, 86,
87, and 87. That
"a" makes a
HUGE difference and I'll explain the difference below.
I'm 'bout to go into DYI mode:
When you send power (low beam from the car) to the
30, it should send it directly out the 87
a (to the low beam wire on the JDM harness), which will be your default setting. And when you activate the high beam wire (from the car), power is sent to the relay coil
85 to shut the low beam filament off and activate the
87 high beam filament (the high beam wire on your JDM harness).
Oreilly's relays:
Since there is no 87
a pin on the relay, and just two
87 pins, there is no low beam, or default setting. When you send power to their
85 relay coil, both filaments activate, since there are two
87 pins, prematurely burning up your bulbs and possibly your wiring. Basically, when you turn your lights on, you have no low beams at all, but you flick the switch and you have lows and highs coming on at the same time. That's not suppose to happen. You're only suppose to have one filament come on at a time.
It took me 3 days of anger, frustration, trial, and error to finally figure out that it wasn't my wiring that was wrong, it's just that I had bought 4 brand new pieces of "caca el toro." That's "bullsh*t" for those who don't speak Spanish. Your best bet is to get some
Bosch or
Bosch-style relays from
ebay. and make sure you look for the 87
a. I hope this helped or helps someone out so you have to endure what I endured. If you have any questions, feel free to PM me. Being that I'm somewhat of an expert at these things now, I may be able to help you out if you don't understand something.
Daryll
