After reading thread after thread about slow windows, I though I'd post a DIY regarding cleaning the window channels to clear up exactly what steps to take. This is cheap fix for the slow window problem that may save your motor(and $$$) in the long haul.
What I used:
- Rubbing alcohol
- Q-tips
- Paper towels
- Silicone spray
First, wet the Q-tip with the rubbing alcohol.
Then run the Q-tip up and down the side channels.
You are going to need a few Q-tips, it gets pretty nasty in there.
I then stuffed a paper towel in there, and moved it up and down along the channels.
Once the channels are nice and clean, I lubricated them with a silicone spray.
If your spray doesn't have a straw-like spray nozzle (like WD-40), you may need to pull the channel open a bit to really get it in there.
There you have it. A very simple solution to a problem that many owners of older cars may face.
What I used:
- Rubbing alcohol
- Q-tips
- Paper towels
- Silicone spray
