Instead of typing it up again, I found an installation procedure written up by Steve91LS after the first batch. I've made some additions to it though.
It's the same between coupe and sedan.
Installation Tips:
by Steve91LS
Tools/Materials:
14mm deep socket, 12mm reg., 10mm reg., hinged ratchets (if possible), flathead screwdriver, zip ties
Time: 50 mins.
1.) Remove the stock brace in order to position the Strut bar easier (12mm).
(on '94 and '95 Legends which have the A/C line running along the factory bar, remove the bracket that holds the A/C line to the factory bar and put it aside - you won't be needing it. Push the A/C line back towards the firewall and tuck it under factory bar's mounting brackets.
2.) Remove the two bolts on the strut tower nearest the engine on each tower (14mm).
3.) Test place the bar.
4.) As you will see, there is a cruise control cable bracket you will need to remove and a wire harness that will need repositioning on the driver side. Remove the rear cable bracket (10mm) and remove the wire harness from its bracket by using the screwdriver to press on the release (flathead).
5.) Place the bar on the towers and hand tighten the nuts. (When putting the bar on the tower, make sure the cruise cable is OVER the bar) It may get stubborn, so the best way to install the bar is to first align the bar up with the studs on the driver's side. Then from the passenger side, push the bar to clear the top of the strut. It may take a bit of elbow grease, but it will clear and fit.
6.) Torque down the nuts using the ratchet (14mm) 5-6 turns each, then switch to the opposite side and torque the nut diagonally across until tight (like when torquing lug nuts on a wheel). This will insure even placement of the brackets to the body.
7.) Zip tie both the wire harness to the tower bar and the cruise cable near where the original brackets would have been.
8.) Re-install the stock strut bar.
9.) YOU'RE DONE!!!
Have fun!!!
That's it, that's all. Like Fut said, we test fitted all of the bars to my car, and they all fit.
I'm sure that you'll enjoy the bars when you get them.
