1 - 14 of 14 Posts
Does anyone know what a blinking D4 light means, I was driving this morning when mine started to blink and the speedometer started going all over the place then rested on zero.
to be striaght without the unwanted commentary, a blinking d4 light could be a couple different things. your sypmtoms sound like the more common,( a bad vss) type it in the search box and you should find some more info there. good luck
has left the building
Way to enable the OP, noob. The way it works around here is that we prefer for people to use the SEARCH function instead of posting useless threads about subjects that have been previously discussed countless times before.
Good intentions, bad execution. Lurk & search before you make wiseass comments to the OGs.
i got a question. what if none of the light is showing?? no blinking or nothing. i will post video soon. but when ever i change all the gear in my automatic shifter, there is not even light. no green one or red one.
Discussion Starter · #9 ·
You might want to search that before blkonblkcpe drills you a new asshole...
Burned out bulb. Now search on how to remove the instrument cluster and/or buy a HELM factory service manual. Everything you could possibly want to know about this car is in here, you just have to look for it.
blkonblkcoupe won't be the one to drill a new asshole. It'll be me if ppl don't figure out how to use the search function. Quickly.
1 - 14 of 14 Posts
