Before modding, make sure that your sensors are working the way they're supposed to first.
The TW sensor is important in that the ECU adjusts the A/F ratio according to temp. Make sure the ECU is seeing the correct temp by having a TW sensor within specs. My old one started to drift a bit and a new one helped the driveability and peppiness.
The next sensor is the O2 sensor. There are two of them and even though the ECU doesn't flash doesn't mean that they're still good. They need to be fast and responsive, As they get old they get slower and don't report back the efficiency of the combustion correctly. The ECU doesn't flash until they're really bad and by that time your performance is way down. So don't wait for the ECU flash.
I went thru this and what a difference!!!!!!
Reminds me of hi-end stereo setups where proper cables, clean contacts and proper setup can make more of a difference than an equipment upgrade!
