1 - 6 of 6 Posts
hi guys recently notice that the light on both the driver side and passendger side does not light up when open. at first i thought it was aa fuse but i couldn't fine the defective fuse to replace becasue there is none. and also yesterday out of nowhere my door charm came on and it scared me because thought it was gone for good. Why is my car so defective and how can i fix it thanks
The switch in the door jamb tells the car when the door is open. This switch can get mashed if the seatbelt doesn't fully retract before you shut the door. These switches also corrode if you live in an area that uses salt.
Try fiddling and wiggling the switch and see if you can recreate the problems. If the switch doesn't move smoothly replace it.
messed with mine twice
I removed mine and sprayed it too with Wd-40 2 times!
**Be sure not to loose that wire hanging out. It can slip in that hole it came out of and Fishing you Go!**
1 - 6 of 6 Posts
