Well, guys, I just found this thread, which is really useful.
I have installed a Bulldog security remote starter, which also has doors/trunk lock/unock option alongs with a bunch of other things.
In this case, I had to trace the wires to lock/unlock doors, and after burning a fuze, I had to cut the wire and tie them in sequence with aftermarket unit. It seems that this unit keeps two wires normally closed, so the factory lock/unlock signal goes rught through. But, when a remote is used, it breaks that line and inserts it's own 12V pulse to lock/unlock doors.
The trunk is simple, I believe I only had to tap into that wht/blk wire, and the unit supplies 12V pulse, which is equivalent to pressing the button on driver's door.
I am still looking for a way to enable/disable the factory alarm. After pocking around for coule of everning, no luck yet. So, for now, I close all the doors, then lock the car with this remote starter unit. To the security system it looks like someone is locking the car from inside, and it is not arming the alarm. So, really, I have no alarm this way. Otherwise, if it is enabled, opening doors, trunk, or remote-starting the engine sets off a nice loud beeping, which is not something I need.
If any of you guys have figured the security side ot this, let me know. Also, if I can help anyone with answers, I'd be glad to do so.
Peace,
pc
