my door is creeking and squeeking horribly its comming from the black rod that goes into the door ..how do you replace this or take it out to at least greese it , cause i;v sprayed tons of **** in there with no results
PS it is really bad its not alittle squeek you can feel it rubbing metal on metal and the door is harder to open then others does this part go bad ever? oh and what is this part called so i can stop refering to it as the part
