door won't shut cleanly - wind noise results
710 Views 1 Reply 2 Participants Last post by  LPB
Hello.
I have a 91 Legend L Coupe. The driver's side door won't shut cleanly: there is too much overlap between the upper rubber moulding on the door and that of the door frame - there is enough space between these that on the freeway the wind noise is really intolerable - especially considering that I just dropped a couple grand on a very nice stereo system. Is there an easy adjustment to remedy this?
thanks.
1 - 2 of 2 Posts
Is your active striker working? It should bring the door in a bit after the door is fully closed. If it is, you could also try adjusting the active striker which will provide some limited up/down/fore/aft adjustment. You need to use liquid thread lock when you position for the final time.
Are you sure it is the door adjustment and not the window glass - weatherstrip or even air from the outside mirror? There is a TSB re Wind Noise.
1 - 2 of 2 Posts
