I tried searching the forums for this I had no luck. How do you install the driver's foot rest (I am not even sure what that part is called, kick panel perhaps?) Anyway, it is that big plastic piece located on the far left where the drivers side courtesy light is. I have the part and there are screw/bolt holes but since the part is completely covered from the top do you bolt it in from the back side (behind the fender liner?). Also, I am not sure if I have the correct bolts for the part so if anyone knows the bolt size (length, width, and thread pitch) that would be awesome.
I am sure this will be pretty obvious when I do it but does the bolt go down through the floor and the nut tighten to the back of the fender/quarter panel or does it come up through the floor and tighten down to the foot rest?
