1 - 6 of 6 Posts
Hey everyone. Right now I'm looking to drop 2 Alpine SWR-1541D 15" Dual 4-ohm Voice Coil Component Subwoofers into the back of my legend, but I need some help finding the right box. I'm looking for a dual 15" sealed box. Would like to spend no more than $150.00, but want quality, any advice?
Well, first of all good luck with the 15's fitting and making sure your box has enough airspace. Also, i dont think any dualy 15 inch box will fit in out trunks. It will need to be custom and that will cost more than $150.
know 'm ool
prefab sealed boxes should be fine in terms of quality at least for a sealed box, i just might want to make sure they have near the right amount of airspace, but yea, you might be able to get it in your trunk, but it probably won't use the space very well, and u won't have room for anything else
if you want something custom, it's gonna cost probably a lot, and it all depends on the shops around your area, you might want to go around and ask.
i would just build it myself, it's not that hard, and might cost you around 40 bucks, for all the wood, and carpet and everything
You cant fit a dual 15" box into your trunk and I think it is stupid because no one NEEDS 2 15"subs. If you want a prefab box than u want the cheap way out, and by doing this i know you wont dynamat or linex anything like that. Your rattling will be just as loud as the subs.
Do it right or dont do it at all, that is my suggestion and if your funds do not allow for a custom box than step down to 2 12" subs that hit hard.
1 - 6 of 6 Posts
