What does it mean if the yellow LED is solidly illuminated with no red led flashing (I know the RED LED works because it recently reported the front o2 sensor bad)? I "THINK" it means the EICV is having a problem but it does not show up
Found a 2.5L core at the local junkyard for $200, have not decided if I am going to get it and rebuild. The yard owner says the engine runs but needs rings. He has several 2.7s that he sells as running rather than cores but I think I am going to stick with the 2.5 unless someone gives me a good reason to switch...
