Just try to get the right offset of wheel...closest to the stock offset of +65mm, i.e. +45 is optimum, yet you can go as low as +40 offset (slight scrubbing)
optimal offset would probably be as close to stock's +65mm as possible. I say best would be in the +50s. But these are extremely hard to find and expensive. By try to get high offset, I think +45 is a minimum. Anything less you might run into rubbing problems. So play it safe and get as high as possible if you can.
I have +51mm offset
