DV8's CAI
4241 Views 27 Replies 13 Participants Last post by  Dv8
I can some this thing up in one word SWEEET!
It costs a few dollars less than my RM Racing intake(which I got in 97).
Installation was a little more involved than a normal intake but well worth the extra effort. Over all I noticed an improvement over my old RM intake and I'm very happy. The sound the RM Racing intake made while at WOT was sweet but it just can't compare to DV8's.
If you're planning on getting an aftermarket air intake why spend more to get less? Why not just get the best **** intake to start with?
If you're already have an aftermarket intake(not a CAI) you'll get better performance with DV8's. I can't speak for those of you who have already installed a custom CAI but at least in terms of appearance DV8's CAI looks top notch.
Thanks DV8 and sorry it took me so long to post my results.
1 - 20 of 28 Posts
Swweeeeeeet.
how long did it take u to install it? any proffessional work needed?
DV8 how much are u selling this for?
i was gonna go buy the RM but waited for ur post. i wanna try this out
-hass
DV8 may have already posted pics some time back, but if you could post some pics. Thanks.
If we could buy the pipes (from DV8) and they fit an RM it would be great also...:D
Sounds great. I'm glad to hear that people are happy with DV8's CAI, I knew that they would be. Hopefully now if enough people start buying this thing he can sell the CAI extension to us that already have any intake :).
hey, im not familiar how this CAI works, but i would like ot learn
-thanks
-hass
See i cant guarantee fitment to any other intake because it may be longer or shorter than the one i use, therfore not fitting well or at all.
-thanks
-hass
ANY CAI's Purpose is to draw colder air(outside engine bay air) in to the engine aiding in a more powerful combustion, thus increasing power.
My CAI will position it self right in the path of cold air behind the passenger -side bumper. On 91-93 sedans and all coupes the fog light cover can be removed for RAM air effect(direct airflow to filter or opening).
94-95 sedans alrady have an opeing through its existing lower grill.
~Hybrid
I bought Dv8's CAI too. He sent it out Friday at 3:00PM and I got it at 10AM the following morning. I installed it the same day I installed a Monster Cable battery clamp.
My prior intake was the stock box. I had to remove the front bumper of my Legend L sedan to get at resonator box and place the K&N air filter onto the CAI extension. I had no idea the stock intake stuff took up so much volume. Being a slow DIYer, it took me a while to figure out what I wanted to do. The breather Dv8 gave me didn't fit over the crank-case valve, but I found some Mercedes rubber part that the breather would fit Then I just secured the other end over the valve.
I found that the air filter is a tight fit behind the passenger bumper area. Right now, its pressed against the side of the front bumper.
I just took my car out today for the "test" drive. I don't know what an air intake is supposed to sound like, but I didn't really notice any extra volume or noise that the CAI created over the stock intake, except at wide open throttle. I already have a Remus exhaust, so the CAI just added a little volume to the stuff the exhaust already made.
Drive conclusion: Dv8's CAI is awesome! Whenever I slammed down on the pedal before, it took my engine a while to gather enough air to get first gear going. Since I have automatic, whenever I time myself doin' 0-60 on an expressway, I notice that I take first gear up to near redline and then finish it off with second.
Now it appears I don't have to do that anymore. The RPM gauge jumps up instantly when I step on the accelerator. The automatic shifting between gears is much smoother. I recommend this CAI to anyone who would like to put a little more pep in a Legend.
Great. Im glad you think its awesome.
Ill defenitly address the breather fitment, and the K&N filter resting against the inner-side of the bumper. ALso im going to find some tech diagrams showing the removal process of the Legends resonator box.
Thanks again
~Hybrid
fast idle valve
Christian, when you commented on this I took notice because my car always jumped RPM's for some uknown reason when I was stopped and after reading your post I noticed that it only happend after I put on my custom CAI. You said that you pinched it someway to restrict the air flow instead of a breather or closing it completely, I had a plastic plugg in it and it was not working so I cut the idle hose to about 2 to 1.5 inches short and kept the plug in it but drilled a small hole in it and, just like that no more problem....sound safe?
I forgot to mention that your CAI looks really clean, If I didnt already have one...I'd be your next customer...I still want to know what it sounds like!!!:D :D
as long as you dont think that the part or peice that you inserted in the tube can be sucked in.
~Hybrid
it will work
it wont get sucked in, it works though if you saw it, its better than a pinch, hehe
CAI eval
After one week of testing, I can say I am definitely happy :D with Dv8's CAI. I have noticed the increased pick up, especially when punchin' it! And the sound at WOT says "Get the FUG out of my way!!" The misses is complaining about whiplash though. :rolleyes:
Install was a tight fit, but I spent more time cussin' while removing the resonator box.
Plus, the fact that my coupe is breathing better makes me feel all warm inside. :)
Thanks Christian.
CAI HP
About how much horsepower do you think the custom CAI's give??
oh and pescador, I know, aren't those a pain in the arse the take out!!!
but the increased airflow that these give you are a lot better than stock by far.
I dont have one of christians, i made my own, but his sound promising.....christian can you patent a CAI for a Legend?
your on your way..........."Dv8 Customs"
Re: CAI HP
2low2go said:
"Dv8 Customs"
Now that would be sweet :cool:
Re: CAI HP
"Dv8ed Customs"
~Hybrid
I'm convinced, saving my money for DV8's CAI.
Was the TCS fit ever resolved?
Dv8ed Customs
"Dv8ed Customs" I like it, Now if you only had a shop....you'd make a lot of extra dough.
Custom CAI for an ACURA LEGEND
Headers (hopefully something)
what's next????????????????:D
2low2go but not slow!!!
1 - 20 of 28 Posts
