801 - 820 of 1,017 Posts
DSL said:
so... if you were selling these cams and were making an ad for them.. i guess you can say that the cams add 26hp and 23tq.... :pimpgrin:
also than the 3.2 to 3.5 dv8 has a lot of other things as well, remember its the synergie of the whole is greater than the sum of the parts
That's being able to watch his headers and other mods in action along with the cam.
For the 3.2, we'll gain more around 10HP, but it extends the usable powerband.
.... yeah, i knowthat the cams alone wont make all that power. thats why theres a pimp grin... and thats the way manufactures seem to claim hp/tq gain on their products... curious, did anyone dyno the other crower cams?
hahaha, have you seen the specs on that cam? It looks like it probably won't even idle. There's probably no way our lifters can adjust to compensate unless they had weld added on. Even then the kind of lift that cam has makes it look like we'd have to get custom roller lifters for the lobe not to lock up.
Discussion starter · #805 ·
You know i was thinking the same thing back when i saw this, but i really think that the duration is longer and the lift is cut down from stock. The numbers are really confusing. They list lift .348 at the top then .232 for both at the bottom
I really dont get it. But trust me on this. If lift is anywhere over .252 it wont spin. As you saw mine are 1-2mm off from touching the casting. The guys that bought the crowers should try and laythem into a head and see if they touch.
INTAKE
Duration:264 degree
Lift:.348
opens: -17.0ATDC
closes: 29.0ABDC
EXHAUST
Duration:264 degree
Lift:.348
opens: 37.0BBDC
closes: -25.0BTDC
Lobe Seperation 117degree
Duration for both Intake and Exhaust is 192 degree
Lobe lift for bot Intake and Exhasut is .232
~Dv8
well lemme tell you this, i talked to the people at crower and web to do some comparisons. Crower is much cheeper as far as price, but i kinda got the feeling from them that quality is also sacrificed. Im sending mine in to web next week.
Discussion starter · #807 ·
Yea much more expensive but my results speak for itself. + they made that grind without using a head to see what they had to work with. to come within 1-2mm from the casting is great engineering or just great luck.
What are you going to get grind wise?
~Dv8
~Dv8
honestly, its great luck. Thats pretty much perfect thought........
348 is the lift at the valve, 252 is the lift at the cam. Divide one by the other and you get the rocker ratio which appears to be incorrect in this case.
You could fit 0.300 lift at cam in by either reducing the base circle or clearancing the head. Base circle reduction is a problem as it changes the rocker angle and the wipe of the lifter on top of the valve.
Chris
Didn't you use to get close (~10-20 more) to those N/A numbers on the nitrous? Either way you have very few excuses not to pull a sub-14 at this point.:bootyshak Since you have the most power to the wheels at this point for this motor (except Buzzard I presume), you may want to do your N/A runs first incase something decides to let go with the nitrous.
Discussion starter · #811 ·
You are damn right son! I should pull a good low 14 if not a tall 13. I will do a few N/A runs first regardless. I have to test out the track for traction anyway. It usually takes an hour or two of cars running the track before it gets sticky.
Its all good.
Ryan, you should have more faith in my Nitrous tune!
~Dv8
I have faith in your tune, this all just seems too good for something bad not to happen. Maybe I'm just used to my own luck, in which case I'd never get close to that power output with similar mods, and the first run would result in oil or trans-fluid spraying all over the engine bay and track.
But yeah, you have to get a 13.999 or better!
Discussion starter · #813 ·
I dont do childs play! :p
If I remember correctly this new setup on nitrous is about 40 more horsepowers to the wheel? Even if he doesn't break into the 12's from traction problems (doubtful), he'll probably trap around a 110. If DV8 does that the question will be: What next?:yumyum:
PS: Christian, don't you dare say "retirement", you already tried that stunt once before. :)
Hmmm, I think I know what's next. First DV8 will put his AEM to use. After coming up with a reliable tune, he will probably see quite a gain, not to mention the ability to push the engine enough to start investing in strengthening up the bottom end. I then foresee the use of some slicks and resulting 12 second passes with no problem. But that's just IMO.:yumyum:
Discussion starter · #818 ·
Forget all that, if i dont see 12's as is within the month of June/July i'll retire for sure. With what ive been squeezing on the street today is childs play to that 13.30 i hit 4yrs back. Its amazed me why i waited so long to squeeze again. Guess i just wanted to have the saftey of a stout setup.
Not to be optomistic but im guessing easy 12.999@107MPH
~Dv8
When I say easy 12's after your AEM and some slicks I don't mean high 12's I was talking more about low 12's, possible a 12 flat if you reduce as much weight as possible. And even then I'm talking on the same shot of nitrous you're currently spraying. You will run a high 12 with the dyno you just pulled I would almost guarantee it, but you're right "knock on wood".
After the AEM and making sure everyting is stong enough to take it, you'll be able to spray a much larger shot of nitrous and for the sake of not jinxing you I won't say what time I have in mind, but I'm sure you can guess. :)
I would have to agree Christian, get the AEM in there, reduce tail weight and slap on a set of slicks. Then go get your 12sec. even.
