1 - 6 of 6 Posts
HOw do you take the fuse out of the ECU or whatever u have to do to reset it? i heard u should do this when u do stuff to the engine. thanks
502MotorSports.com
cool beans Cody!
Shad, when you remove the fuse, it resets the ECU. It will now be in a "learn" mode and will adapt to the changes it senses in air, fuel, etc. If you think about it, many times you do modifications to your car (other than eCU swap), they may ask you to remove the negative battery cable...you will see a difference in time.
1 - 6 of 6 Posts
