1 - 9 of 9 Posts
Gangstar* User
So started on the Rack and Pinion. What a fun chore.
So had all the pics going on, for a DIY and all was going good, got the old one out
cleaned up the underside of car cause it was nasty
then proceeded to put in the new rack....
well that was a bitch
been working on it for about 2 hours when BAM
its already ligned up on the drive spline and up there good
for the 2nd time
WHEN A BOLT BREAKS OFF IN ONE OF THE HYDROLIC lines that attaches to the steering gear box !
so the garage is half open, im sitting here sad, about to cry, and dont know what to do
and I needed to vent
Fu*k
for the 2nd time
Fu*k
Just relax and don't work on it till you've cooled off a bit. Like Alp stated you could probabbly use the bolt or line(what ever part needed) from the old one. If it's a line then just clean the line out(including inside) and swap. If it's a bolt just use a bolt extractor that you can usually get at any hardware store or autopart store. What ever you do just be careful and patient. Take pics and post, maybe we could help you out better that way.
Gangstar* User
Okay
so I was having a really bad night
i probably shouldn't have posted this but owell
Finally got the rack in and am going to try and get a DIY made soon
but bad news is my car squeeks still and I have no clue what it could be
1) only happens when turning steering wheel
2) only squeeks when car is on ground; when jacked up and turning the wheels it doesnt make the noise
Anybody ?
Does anyone know if my steering wheel can be straightened when i take my car in for an alignment ?
FRISCO LEGEND BABY!!!!
You should have someone turn the wheel while you search for the squeeky sound. Hope you find the problem.
Gangstar* User
Haha I tried that
I felt like P.I. searching for clues!!!
but im going back out there soon to try again
then im going to go crazy with some
White Lithium Grease ! woot
From suspicion i think its the upper control arm bushings, or the lower balls joints
grrrrr
Gangstar* User
Discussion Starter · #9 ·
I hear it whenver I turn the wheels and pull down my drive way
it doesnt squeak when I am going down the highway or down the road
so its not on the Y axis of movement
grrrr
It happened after I hit a speed bump
it makes me sad
And I figured after new shocks/springs and my leaking rack and pinion
it would quit
but guess i was wrong
1 - 9 of 9 Posts
