1 - 7 of 7 Posts
hey guys i was wondering if theres ne cars out there tat u would plug in my 1995 legend sedan and play around with... if u can tell me thx u
I'm sorry, you don't seem very clear in your post.
Are you asking about Engine Swaps?
The only viable engine swap is the Type I engine (200hp) to Type II engine (230hp).
This will set you back about $4-6k.
okay ? if i did get the Type II swap can i get it into a Manual cuz i have a Type I auto right now...??
· 502MotorSports.com
Anything is possible.....but you will need to spend some $$$...depending on where you go. Only one person has been successful so far...I hope to be next
Not sure if your referring to TJ, he did a auto to manual conversion:
He has the supercharger pulley, bracket and piping all complete. By next year he declared a fully functional SC will be installed. For those that saw the pic of the SC, it will now be on the right (passenger) side where the intake is located (he changed the setup).
yes, I was referring to TJ Miles...interesting that he changed the setup
· Sleek And Low
That's the only location I could see using as well. And don't forget DV8's motor swap too. He kept the auto tranny. But for the most part, unless you need a new motor anyways it's not worth the time and money to swap a motor for only 30 more hp.
Hey, I've got a 350cu in smallblock in my garage. Let me go check and see if it will fit real quick! The funny thing is that I'm not joking ;)
1 - 7 of 7 Posts
