1 - 8 of 8 Posts
Ever since I changed all my hoses to Akimoto Blue my engine light comes on and stays on all the time! I took the car to Honda and they assured me nothing is wrong. How can I stop this dam* distracting light?????:confused: Furthermore it would not come on at the dealer...only when I drive it!
check the ecu.
the codes are up on this section.
also, try resetting the ecu that might do the trick. i had that before and it got fixed after i reset it. when you reset it, do it by disconnecting the batterry. leave it like that for about 30min. might not have to be that long but that's what i did.
-j
Vacuum?
Make sure that the vacuum hoses are all attached; the ECU could be sensing a loss of vacuum and turning on the light. Also you may have hooked one of the hoses up to the wrong place (like crossed them or something?) A dealer probably wouldn't check every little hose...
Just a thought... It really HAS to be the hoses I would think...
-Ben
1 - 8 of 8 Posts
