1 - 2 of 2 Posts
on a cold start my engine will start fine and rise to about 1500rpms then it does the usual let down, as the car warms, gradually to 750rpms. occassionally it will start fine and rise to the 1500rpms then die and stall out immediately. i know the electronic idle controll valve might have a play but im not sure. i heard that some ppl just cleaned the screen in the eicv and it prevents the car from stalling on cold starts. what do u guys think. i know for sure the air filter and fuel filter is fine, they were just changed within the past 6 months and i run 93 octane. also coolant level is perfect i just flushed that a month ago. its no biggie it only happens like once every two weeks, but im thinking its leading to something. also i just adjusted my idle, using the green light in the ecu, last week...so that should not be the issue. thanks
1 - 2 of 2 Posts
