I have a 1987 Legend 4 door. Recently, I noticed that the radiator was leaking along the top seam. As there was very little antifreeze leaking, I didn't think anything of it. Then the erratic idle began. Some of you may know the symtoms--car starts fine, runs fine and then at a stoplight the idle dies down (when the AC cycles on and off) and starts to "jump" and sometimes the car cuts off (with no problem restarting). II took my car to my mechanic who mercifully diconnected the AC compressor for me. Since he disconnected it, no more erratic idle. Prior to disconnecting the compressor, the AC ran fine. I am happy that the car is running again but I am not happy that the AC is down. I am going to have to replace the radiator (anyone know which aftermarket one is good?). I thought that I also may want to replace the IAC valve as well. Anyone have any ideas? I seem to recall many years ago that I had an erratic idle before and the Acura dealer said I needed a radiator. Once they installed it, the erratic idle went away. Anyone have the same experience?
Thanks!
Thanks!
