1 - 7 of 7 Posts
I know Leon, recently put up a process about this, but I am still confused.
On my G1, you just turn on the power, and look at the footwell, there's a plexiglass window there that flashes codes.
What's the process on the G2? I heard something about a service switch??? Where do the codes flash? I looked at the footwell, it looks like it would flash there too like my G1??
GS Hog
No, on a G2, you have to jump a small service connector that is in the passenger footwell, usually attached to the top of the ECU (under the carpet).
Simply jump it with a paper clip or something. The check engine light will flash the codes, and I THINK that the D4 light will flash the transmission codes.
"Small Service Connector"
Am I looking for a cable then? Like a wiring harness?
I pulled back the passenger footwell carpet, I see a little plexiglass window w/led in it... what's that? Looks like the one in my G1 Coupe, couldn't find much more.
GS Hog
Make sure that you have the key to the ON position (car doesn't have to be started).
If all is OK, there shouldn't be any flashing. In fact, if your check engine light wasn't on to begin with, you should get any flashing.
1 - 7 of 7 Posts
