1 - 9 of 9 Posts
Five- O
For some reason the factory alarm is going off for no reason. even when I don't activate it. Just so that I'm clear- The factory alarm get activated when you close the driver side door and lock the door when the key from outside... correct? Is there a easy way to get rid of the alarm?
Help me please !!!!
Esti
buks easy fix for buzzers and beepers etc...
Make the alarm go off...
Listen for where the sound comes from...
Shove your biggest screwdriver through the thing making noise.
it's fixed.:D
Five- O
The factory alarm noise comes out of the horn- so that won't work.
Five- O
I figured out why the alarm was activating. My weapon r filter was rudding against the two wires connected to the hood sensor and had cut one of wires off.
ohh prior to me seeing that I tried to deactivate the alarm by disconnecting the alarm system control unit under the drivers seat. Everything went fine until I went to turn on my car and nothing happened. It has a kill switch so I had to reconnect it.
Thank guys
Esti
aaahhhh the infamous "unrelated mod" bug bites again...
It's funny how sometimes changing your windshield wipers can cause your left rear turn signal not to work... ;)
I once installed a fire extinguisher in my Suburban on the Trans hump... weeks after that I noticed CB didn't work, don't use it much except on trail rides... and of course, the "unrelated mod" was the fire ext....
With a 1/8 inch screw I had hit the only wire in a 3 Foot area...:rolleyes:
Glad you got it figured out E...
1 - 9 of 9 Posts
