The fan on my engine keeps running even after the car has been off for sometime, this just started. Any ideas as how to stop this(fix it) I have taken the fuse out to stop it over night so as not to run down the battery.
the fan will automatically turn off after the coolant and engine has dropped to certain temperature. The fans run to prevent over heat while the engine is off and helps to prevent blown head gasket. Don't worry about it... If you don't feel like seeing it often, consider flushing your coolant and adding redline water wetter to improve engine cooling.
HOLY SH*T:eek:
