1 - 11 of 11 Posts
hello i heard that the fireball exhast produces shots of flames when reving it to certain rpm. however would you recommend it? And if not what kind of exhast system would you recommend?
thanks
like in fast and furious?????? i wonder where you can get those and how much it would cost...
Well I was reading the anarchist cookbook a while back and there was instructions on how to make your muffler into a flame thrower. Drill a hole into your exhaust pipe. Screw a spark plug into the hole. Wire the spark plug to the battery. Connect it to a switch, when flicked on, the spark plug will spark, setting your fumes into flames. Never tried it though... but my friend is gettinga loaner car from Toyota... :D
there's a dutch auction for 5 of em' on eBay...running about $120 each. not a bad deal.
Its an old hot rodding trick. Started out with carburated cars. Run the engine till the exhaust got hot, shut off the engine, pull the choke and quickly start the engine. The rich exhaust vapors would ignite in the hot exhaust pipe shooting flames out the tail pipe.
Later, people started putting spark plugs in their tail pipe so that they didn't have to shut the engine down and turn it back on. Later still, people would retro fit old army flame throwers to their exhaust to REALLY shoot flames out the back.
Today, you see unburned fuel in the exhaust of turbo charged cars ignite in the exhaust. Since race cars run a slightly rich mixture and the exhaust for turbo cars run so hot, flames shoot out the exhaust when the driver lifts off the throttle.
1 - 11 of 11 Posts
