Don't get hung up too much on power output.
RF is good, I prefer Alpine V12. Maybe not the BEST, but definitely a top contender of a amp. I also prefer the style of Alpine over other amps on the market....looking good weighs in as much as sounding good to me.
FYI, sound, DB's and RMS power are never as clear cut as saying "more power is better".
For example: a 6.5 inch speaker
A single 6.5" speaker may produce 92 dB at 1 watt/meter.
2 6.5's getting 1 watt each will produce 95 dB 1 watt/metter totally. Every additional speaker adds 3 dB at 1 watt.
To actually percieve something being much louder, 6 dB is the threshold at which humans will percieve the volume increase as signifigant.
For 1 speaker, twice as loud is actually measured as a 6 dB increase. To sound twice as loud, or gain 6 dB, amplifier power needs to be increased 10 fold. So, 92 dB @ 1 watt.....98 dB at 10 watts, 104 dB at 100 watts, 110 dB at 1000 watts and so on.
So, you can see, a RF amp making 50 watts RMS more or less than another amp is not a big deal. Look at power availibity, such is it's actual rating at 12 volts, not 14.4....and it's ability to multiply it's power outputs at lower impedances like 2 or 1 ohm. Also, consider if the amp looks good in your car with your current or ideal setup.
Just don't get hung up on watts available at 14.4v into 4 ohms...that is not the entire story.
