well assuming you have a '91, you gotta pop open those fog light covers and get underneath. You'll see a hole on the inner side of the lens (from the bottom). if you look carefully past the styrofoam, you'll see one screw. Get a long phillips screw and unscrew. That should be it. Sometimes the nut that holds the screw becomes loose (turns with the screw). That happen to me so i just took the bumper off.
