Reserve is set to $3K. I'm hoping to get closer to 4.
I've put a bunch of work into it recently including:
(off the top of my head)
  • new master cylinder
  • new driver side CV joint with a lifetime warranty
  • complete overhaul of the AC system
The AC work includes some replaced lines, new compressor, new filter-dryer and new evaporator. The desacant bag in the old filter-dryer ruptured and dumped desacant pellets throughout the system. Removing the dash for that job is the reason the door locks don't work. I forgot to connect a cable when putting it all back together. Easy enough to fix.
The tires also have a fair amount of tread left. I need to go out when it finally stops raining here and put a caliper on the tread. It also had a timing belt and water pump replaced for regular service about 3 years ago.
