41 - 59 of 59 Posts
This might be off topic but I am contemplating on whether or not to buy the front and rear sway bars as Never Enough Auto replied to my e-mail today for $290 shipped. If I do get them, I will also buy the bolts. My question is, do you guys feel a big difference between the stock bars and the aftermarket addco ones? I've tried to do some searching but didn't come up with many results. Also my struts and springs are tighter in the front and more loose in the back, would my car be skipping in turns if it's too loose with the sway bars?
· EDM KA8 owner
Discussion Starter · #43 ·
You'll feel improvement with the Addcos. Handling is much better. Rear one is easy to install you can do it yourself and you can later install the front one if you need more neutral handling. I have both installed and I'm satisfied much stiffer comapered to oem bars.
· Fut RIP
put me back a set of these and do you need these for the front as well or just the backs?
· EDM KA8 owner
Discussion Starter · #55 ·
Do you still have these on you since 09 I'm new with the legend bought mine back in 2010 would like a set
Currently out of stock, limited quantity will be ready in the following weeks depending on the machine shop.
· Fut RIP
put me down for a set or 2
I just checked out the pricing for a new ADDCO sway bar and it comes with new hardware:
"includes 12-gauge zinc chromate plated brackets with fully enclosed bushings and heat-treated end link bolts for added strength."
Are the bolts supplied with the kit not good enough?
41 - 59 of 59 Posts
